Subversion edu instructions
How to provide and manage your educational material on osgeo svn
Find out what is there so far: http://svn.osgeo.org/osgeo/education/
Install the svn client software (you may already have it)
Linux: * 'subversion' package (deb or RPM for your distro, should be on the CDROMs/DVD)
MacOSX: * http://subversion.tigris.org/ -> Downloads
Windows: * http://tortoisesvn.tigris.org/ -> Downloads If you want a pretty graphical user interface, 'TortoiseSVN' integrates nicely with the Windows Explorer.
For a comparison of (graphical user interface and command line) subversion clients, see here.
Checkout the material from the SVN repository into local directory
Command line:
svn co http://svn.osgeo.org/osgeo/education/UnderDevelopment/ UnderDevelopment
TortoiseSVN:
Just enter this url: http://svn.osgeo.org/osgeo/education/UnderDevelopment/
This will check all the material in UnderDevelopment/ into the local directory UnderDevelopment/
Now add your material....(you need to have commit access - you will be asked for OSGeoID/passwd):
cd UnderDevelopment/
If you are just starting, add a directory for your institution (svn add is for adding, but you also need to committ by svn ci)
mkdir MyUniversity
svn add MyUniversity
svn ci -m "MyUniversity added - some useful comment" MyUniversity
cd MyUniversity
create or copy your material here and then add the relevant
subdirectories and files to the repository
svn add directory
svn ci -m "MyTutorial for beginners added" directory
svn add file
svn ci -m "Introduction text added" file
Your group can now work on the material
Before starting the work update to latest version
svn up
Modify/fix/enhance the material and commit the change
svn ci -m "Introduction modified, grammar fixed" file
Brief SVN reference
Help:
svn help svn help up svn help mv ...
Update from SVN server:
svn up
This can happen:
A Added D Deleted U Updated C Conflict - ZAP! In this case check for problems G merGed ? file not under version control (e.g. images)
Find out if you have uncommitted changes in your local version:
svn status
If no output, everything was uploaded to SVN. Congrats.
Verify changes before submitting:
svn diff
Commit changes to SVN server:
individual file commit: svn ci -m "Some useful comment" file1 [file2 ...]
or (for global commit of all changes), simply: svn ci -m "Some useful comment"
Add new file/directory to SVN repository:
svn add file svn ci -m "Some useful comment" file
svn add directory svn ci -m "Some useful comment" directory
Remove file from SVN server (careful!):
svn rm file svn ci -m "Some useful comment" file
Move file to another directory (this is the cool feature of SVN):
svn mv file ../some_dir/ cd .. svn ci -m "file moved because ..."
Make new directory (see also svn add above for simplicity):
svn mkdir newdirectory svn ci -m "we need a new directory" newdirectory
Oops - submitted a wrong change? Revert!
svn revert file
See last changes after updating:
(BASE: the revision you updated to, PREV: previous) svn diff -r PREV:BASE svn diff -r PREV:BASE file
Check history of changes (see here for details):
svn log file
... on all files:
svn log
... create ChangeLog file:
svn log > ChangeLog
Handling SVN conflicts (please read the svnbook if unsure!):
http://svnbook.red-bean.com/en/1.1/ch03s05.html
Whenever a conflict occurs, three things typically occur to assist you in noticing and resolving that conflict:
- Subversion prints a C during the update, and remembers that the file is in a state of conflict.
- For every conflicted file, Subversion places up to three extra unversioned files in your working copy
- At this point, Subversion will not allow you to commit the file until the three temporary files are removed.
$ svn commit --message "Add a few more things"
svn: Commit failed (details follow):
svn: Aborting commit: '/home/sally/svn-work/sandwich.txt' remains in conflict
- If you get a conflict, you need to do *one* of three things:
- Merge the conflicted text 'by hand' (by examining and editing the conflict markers (<<<<< and >>>>>) within the file).
- or: Copy one of the temporary files on top of your working file.
- or: Run svn revert <filename> to throw away all of your local changes.
Once you've resolved the conflict, you need to let Subversion know by running svn resolved. This removes the three temporary files and Subversion no longer considers the file to be in a state of conflict:
$ svn resolved sandwich.txt
Resolved conflicted state of 'sandwich.txt'
Reference (really good)
Version Control with Subversion: http://svnbook.red-bean.com/nightly/en/index.html
See also
Graphical tools for SVN http://en.wikipedia.org/wiki/Subversion_%28software%29#GUI_front-ends.2Fclients
