Shptree notes
shptree Processing Notes
(for the Benchmarking 2010 exercise)
shptree Depth
No depth parameter was used for the shptree command, which means the shptree code would determine the optimal depth. The determined depths were:
| file | depth |
| building | 21 |
| contour-0 | 16 |
| contour-1 | 17 |
| contour-2 | 17 |
| contour-3 | 17 |
| contour-4 | 17 |
| contour-5 | 15 |
| contour-6 | 17 |
| contour-7 | 17 |
| industry | 17 |
| motorway | 10 |
| point-labels-for-geometry | 15 |
| point-labels-no-geometry | 18 |
| ramp | 14 |
| road | 14 |
| settlement | 16 |
| track | 16 |
Verifying the qix file
- shptreetst utility was used to verify the integrity of qix file
- you should see a message like:
$ shptreetst contour-0.qix
This new LSB index supports a shapefile with 221671 shapes, 16 depth shapes 0, node 4, -8.187613,36.166759,3.274251,43.666687 shapes 0, node 4, -8.187613,36.166759,-1.883588,40.291719 shapes 0, node 4, -8.187613,36.166759,-4.720399,38.435487 shapes 0, node 1, -8.187613,36.166759,-6.280646,37.414560 shapes 0, node 2, -7.329478,36.728269,-6.280646,37.414560 ... read entire file now at quad box rec 20 file pos 1000 using last read box as a search result of rectangle search was 86554, 86580, 86586, 86598, 86638, 86641, 86642, 86643, 86660, 86667, 195862, 195895, 195901, 195903, 195926, 196873, 197711,
buildings.shp
- shptreetst building.qixcaused a Segmentation fault initially on our BenchmarkB Linux server (with 8GB RAM)
- to solve this we...
