OGC XML Schemas and FOSS4G Software Distribution
Background
Blogpost: http://www.how2map.com/2015/02/a-good-test-for-ogc-and-osgeo.html
Discussion on OSGeo-Standards mailing list: http://osgeo-org.1560.x6.nabble.com/OGC-XML-schemas-and-FOSS4G-software-distribution-td5186023.html
This issue is not new, however was raised in the OSGeo Standards mailing list as a result of the pycsw Incubation process
Problem Statement
FOSS4G software may encounter distribution issues when including OGC Schemas as part of the codebase.
Use of OGC XML Schemas in FOSS4G Implementations
- used to re-publish schemas:
- XML responses cite
xsi:schemaLocationof pointing to locally cached OGC schemas- e.g.
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2 http://HOST/csw/2.0.2/CSW-discovery.xsd">
- e.g.
- used within software to perform XML schema validity of XML based HTTP requests
- others?
Distribution
Debian
Examples of rejection by Debian:
- pycsw: http://lists.alioth.debian.org/pipermail/pkg-grass-devel/2014-November/024520.html
- TinyOWS: http://lists.alioth.debian.org/pipermail/pkg-grass-devel/2014-January/017321.html
For clarification of the problems the Debian project has with the OGC Document & Software Notice terms see: http://lists.osgeo.org/pipermail/standards/2015-February/000842.html and the links referred to in that message.
Current Text
Per http://www.opengeospatial.org/ogc/legalfaq#DTD, paragraph 5.10:
Schemas (and DTDs) are frequently part of our specifications and seemingly fall under the document copyright terms. However, as long as you do not use the same formal namespace or public identifier to identify that modified OGC schema/DTD (which might confuse applications), you may treat the schema/DTD under the software terms. This means that you are permitted to make a derivative or modified OGC schema/DTD, but even under the software terms you are obligated to include/retain the OGC copyright notice. We further appreciate a couple sentences regarding who made the modifications, when, and what changes were made in the original DTD -- a common software documentation practice.
Document terms: http://www.opengeospatial.org/ogc/document
Software terms: http://www.opengeospatial.org/ogc/software
Proposed Text
Schemas (and DTDs) are frequently part of our specifications and seemingly fall under the document copyright terms. Applications may use the schema/DTD for under the software license. We ask that care be taken when making a derivative or modified schema/DTD to preserve interoperability. As an example a schema/DTD used for internal validation may be modified to validate additional optional vendor options without affecting interoperability. This has no impact on interoperability between applications and the resulting schema/DTD remains embedded in the application. If publishing a modified schema/DTD it no longer qualifies as an OGC schema/DTD and we ask that a unique formal namespace or public identifier be used to prevent application confusion. This request is based on the restrictions of XML technology rather than a license restriction. When using the software terms you are obligated to include/retain the OGC copyright notice. We further appreciate a couple sentences regarding who made the modifications, when, and what changes were made in the original DTD -- a common software documentation practice.
