Live GIS Disc Press Release 77
What's in the OSGeo-Live 11.0 reboot?
29 May 2017
In line with the OSGeo-Live reboot [1] we have identified the following actions:
We will only support a 64 bit distribution, (32 bit will be built but not tested or officially supported).
We will no longer provide:
- Windows installers,
 - Write ups for OGC Standards,
 - Write ups for libraries without a user interface (on a case-by-case basis)
Stray projects: We haven't got a point of contact for these projects. If you know something about this project, and can help review docs, then please consider adopting the project. Without a volunteer, we will need to consider retiring them from OSGeo-Live. Work commitment is low, kudos and karma very high :)
- openlayers
 - osgearth
 - gmt
 - iris
 - jupyter
 - JOSM ( OpenStreetMap editor )
 - proj4
 - mb-system
 - zygrib
Projects recommended to be retired from OSGeo-Live:
- geokettle
 - geomajas
 - javaworldwind
 - kosmo
 - mapnik
 - pywps (quickstart broken)
 - sahana
 - tinyows
 - ushahidi
 - viking
Remaining projects:
- Most projects have at least minor tweaks required for the docs, some have outright errors.
 - We are asking each project to, check their project overview, run the application on an OSGeo-Live VM (10.5 or a recent nightly build), run every step of the quickstart, update if required, and tell us when done.
 - Once verified, we will add the project back into the OSGeo-Live 11.0 builds.
 - We will call on all projects to test their projects and quickstarts again in an OSGeo-Live 11.0 beta.
For specific project comments, see the OSGeo-Live status spreadsheet, column T "11.0 Comment", and column U "10.5 Doc Review".
[1] https://wiki.osgeo.org/wiki/Live_GIS_Disc_Press_Release_75
Key Milestones
- 5-Jun-2017 OSGeo-Live Feature Freeze (final application versions installed)
 - 19-Jun-2017 OSGeo-Live delivered to UAT (final application versions installed - Beta stage)
 - 24-Jul-2017 OSGeo-Live Final ISO
 - 14-Aug-2017 FOSS4G 2017 Boston
About OSGeo-Live
OSGeo-Live (http://live.osgeo.org) is a Lubuntu based distribution of Geospatial Open Source Software, available via a Live DVD, Virtual Machine and USB. You can use OSGeo-Live to try a wide variety of open source geospatial software without installing anything.
