GSoC 2022 Node.js for ZOO-Project
ZOO-Project GSoC 2022 Contribution by @mmomtchev
Adding Node.js support for service implementation to be run from the ZOO-Kernel
Abstract
The ZOO-Project is a solid WPS server able to handle services implemented in various different programming languages. The existing ZOO-Kernel supports C, C++, and JS implementations with the SpiderMonkey engine. With this project, the objective is to add support for NodeJS implementation of the ZOO-Kernel.
Mentors: Gérald Fenoy, Aditi Sawant, Rajat Shinde
Contributor Personal Details
Momtchil Momtchev momtchil@momtchev.com, France +33611640937 https://github.com/mmomtchev https://twitter.com/mmomtchev https://mmomtchev.medium.com
Graduated from the Université des Sciences et des Technologies de Lille with a French DEA in Computer Science (Master’s equivalent)
Currently unemployed and looking for job in open-source
First time applicant to GSoC
Co-author and current maintainer of the Node.js bindings for GDAL (https://github.com/mmomtchev/node-gdal-async)
Author of the React bindings for OpenLayers (https://github.com/mmomtchev/rlayers)
Author of the Node.js bindings for ExprTk (https://github.com/mmomtchev/exprtk.js)
Occasional Node.js and GDAL contributor
Author of numerous smaller packages and tools (https://www.npmjs.com/~mmomtchev)
Expert C/C++ and JS/TS engineer with Linux, macOS and Windows experience
Existing Software
Currently ZOO-Project supports JS services through the embedded version of the SpiderMonkey engine. It is linked as a shared library and every invocation of a service results in a separate instance of the SpiderMonkey engine.
Proposed Solution
The current latest LTS version of Node.js, Node.js 16.x, is to be embedded in the ZOO-Kernel executable following the same architecture as SpiderMonkey.
It is worth noting that the next LTS version of Node.js, Node.js 18 is scheduled to be released during the GSoC timeline. As this version is not expected to replace the 16.x as recommended version until October 2022, it is believed that Node.js 16.x remains the safer choice.
Node.js supports being built as a shared library since version 12.x. This feature is used by the Electron project which is its main maintainer. It allows the JS runtime to be loaded inside the address space of the calling program and to both call JS functions from the native code and expose native functions to the JS code.
There are several different interfaces available for interacting with the Node.js runtime:
- By calling raw internal V8 and Node.js methods which are usually not stable across different versions
- By using the NAN C++ API C++ which is stable at the source level across different versions
- By using the Node C N-API which is stable at the binary level across different versions
- By using the Node Addon C++ API which is stable at the binary level across different versions
Of these methods, the Node C N-API seems to be the best suited for ZOO-Project as it is binary stable across different Node.js versions and it does not require C++.
It should be noted that while these APIs/ABIs are usually meant to be used by native addons that are loaded by the main Node.js process as a shared library, they are also perfectly usable in the opposite direction - ie when Node.js is loaded as a shared library by a 3rd party process.
Node.js supports running multiple V8 isolates, each with a separate main thread, offering a completely separate execution environment to each JS instance.
These separate instances have separate event loops but can share the same worker thread pool.
This mode of embedding Node.js matches most closely the existing JS architecture based on SpiderMonkey. It is also the preferred mode for embedding Node.js.
The following alternatives have also been considered: * Run every instance of a service in a separate, external, Node.js process This mode will have a more expensive startup and will present unique challenges when implementing the various ZOO-Project routines which will have to communicate with the ZOO-Kernel by some external mechanism - such as RabbitMQ. * Run all instances of a service in a single shared environment This mode offers the potentially best performance but it imposes upon the end-user to use very correctly the Node.js asynchronous mechanisms - failing to do so will result in latency spikes and possibly dropped connections.
Rebuilding libnode as part of the ZOO-Project build system is considered to be out of the scope of the current project - just as the current SpiderMonkey shared library is expected to be provided by the end-user, so will be libnode which is already carried by some major Linux distributions - Ubuntu being one of them.
Testing methodology
ZOO-Project already has an existing testing framework which includes the SpiderMonkey services. The new Node.js implementation is to be able to run those services passing the existing SpiderMonkey tests without modifying the services code.
Additionally, an AddressSanitizer build, currently absent from ZOO-Project is one of the stretch goals of the proposal.
Proposal Timeline
I am fully committed to working on this project during this time period and I am free of any other professional obligations.
Before June 13
- To familiarize myself completely with ZOO-Project functionality and architecture.
- To experiment with using
libnode, the embedded version of NodeJS and test the compatibility between the packagedlibnodeby the Linux distributions and the existing Node.js native addons
June 13 - July 25
June 13 - June 17
- Implement the creation of the
libnodecontext inservice_internal_nodejs.cto be called fromzoo_service_loader.c:loadServiceAndRun() - Include
libnodein theZOO-Kernelbuild and link against it in the official Dockerfile - Use a dummy static JS method
June 20 - June 24
- Test building with the versions included Ubuntu, Debian, CentOS and Fedora
June 27 - July 1
- Implement
ZOORequest,ZOOTranslate,ZOOUpdateStatusandalertusing Node N-API
July 4 - July 8
- Implement the object and the array transforms using Node N-API
July 11 - July 15
- Load the existing 3rd party code - mostly
proj4jsinto the environment
July 18 - July 22
- Spare week for testing and debugging
July 25 - July 29
- Phase 1 evaluation: the existing SpiderMonkey unit tests should be passing on Node.js at this point
July 29 - September 4
Stretch goals
August 1 - August 5
- Add builtin Node.js GDAL support
- Allow JS services to use
gdal-asyncout of the box - Reimplement the GDAL profile C++ service in JS as an example
August 8 - August 12
- Create and automate an
AddressSanitizerbuild to be run in continuous integration
August 15 - August 19
- Allow services to request to be executed in a single-instance mode by providing an
asyncfunction as entry point
August 22 - August 26
- Add snapshot support to
libnode- it could benefit from having the same V8 snapshot support as the Node.js main executable. V8 supports creating and restoring snapshots of a JS heap - this feature is used by Node.js to speed-up the initial loading of the JS class library - instead of compiling it at every process startup, it is compiled and initialized once during the build of the Node.js executable and then the JS heap is saved in a snapshot to be reused when launching Node.js. Currently, this feature is not readily available when usinglibnode. Electron re-implements it on its own. This is to be submitted for merging back in Node.js.
August 29 - September 2
After September 4
- Phase 2 evaluation
