Configuration Files Mapnik
Mapnik Python Script for Start-up and Processing
#!/usr/bin/env python from mapnik import * mapfile = "population.xml" m = Map(1400, 600) load_map(m, mapfile) bbox = Envelope(Coord(-180.0, -75.0), Coord(180.0, 90.0)) m.zoom_to_box(bbox) render_to_file(m, 'world_population.png', 'png')
Mapnik XML Configuration File
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE Map>
<!-- Sample Mapnik XML template by Dane Springmeyer -->
<Map bgcolor="white" srs="+proj=latlong +datum=WGS84">
<Style name="population">
<Rule>
<!-- Built from Seven Class sequential YIGnBu from www.colorbrewer.org -->
<!-- Quantile breaks originally from QGIS layer classification -->
<Filter>[POP2005] = 0 </Filter>
<PolygonSymbolizer>
<CssParameter name="fill">#ffffcc</CssParameter>
</PolygonSymbolizer>
<!-- Outlines for Antarctica look good -->
<LineSymbolizer>
<CssParameter name="stroke">black</CssParameter>
<CssParameter name="stroke-width">.1</CssParameter>
</LineSymbolizer>
</Rule>
<Rule>
<Filter>[POP2005] > 0 and [POP2005] < 15000</Filter>
<PolygonSymbolizer>
<CssParameter name="fill">#c7e9b4</CssParameter>
<LineSymbolizer>
</LineSymbolizer>
</Rule>
<Rule>
<Filter>[POP2005] >= 15000 and [POP2005] < 255000</Filter>
<PolygonSymbolizer>
<CssParameter name="fill">#7fcdbb</CssParameter>
</Rule>
<Rule>
<Filter>[POP2005] >= 255000 and [POP2005] < 1300000</Filter>
<PolygonSymbolizer>
<CssParameter name="fill">#1d91c0</CssParameter>
</Rule>
<Rule>
<Filter>[POP2005] >= 1300000 and [POP2005] < 4320000</Filter>
<PolygonSymbolizer>
<CssParameter name="fill">#41b6c3</CssParameter>
</Rule>
<Rule>
<Filter>[POP2005] >= 4320000 and [POP2005] < 9450000</Filter>
<PolygonSymbolizer>
<CssParameter name="fill">#225ea8</CssParameter>
</Rule>
<Rule>
<Filter>[POP2005] >= 9450000 and [POP2005] < 25650000</Filter>
<PolygonSymbolizer>
</Rule>
<Rule>
<Filter>[POP2005] >= 25650000 and [POP2005] < 1134000000</Filter>
<PolygonSymbolizer>
<CssParameter name="fill">#122F7F</CssParameter>
</Rule>
<Rule>
<ElseFilter/> <!-- This will catch all other values - in this case just India and China -->
<!-- A dark red polygon fill and black outline is used here to highlight these two countries -->
<PolygonSymbolizer>
<CssParameter name="fill">darkred</CssParameter>
<LineSymbolizer>
<CssParameter name="stroke-width">.7</CssParameter>
</LineSymbolizer>
</Rule>
</Style>
<Style name="countries_label">
<Rule>
<!-- Only label those countries with over 9 Million People -->
<!-- Note: Halo and Fill are reversed to try to make them subtle -->
<TextSymbolizer name="NAME" face_name="DejaVu Sans Bold" size="7" fill="black" halo_fill= "#DFDBE3" halo_radius="1" wrap_width="20" spacing="5" allow_overlap="false" avoid_edges="false" min_distance="10"/>
</Rule>
<Rule>
<TextSymbolizer name="NAME" face_name="DejaVu Sans Book" size="9" fill="black" halo_fill= "#DFDBE3" halo_radius="1" wrap_width="20" spacing="5" allow_overlap="false" avoid_edges="false" min_distance="10"/>
</Rule>
<Rule>
<!-- Those with over 25 Million get larger labels -->
<TextSymbolizer name="NAME" face_name="DejaVu Sans Book" size="12" fill="white" halo_fill= "#2E2F39" halo_radius="1" wrap_width="20" spacing="5" allow_overlap="false" avoid_edges="true" min_distance="10"/>
</Rule>
<Rule>
<!-- Note: allow_overlap is true here to allow India to sneak through -->
<Filter>[POP2005] >= 1134000000</Filter>
<TextSymbolizer name="NAME" face_name="DejaVu Sans Book" size="15" fill="white" halo_fill= "black" halo_radius="1" wrap_width="20" spacing="5" allow_overlap="true" avoid_edges="true" min_distance="10"/>
</Rule>
</Style>
<Layer name="countries" status="on">
<!-- Style order determines layering hierarchy -->
<!-- Labels go on top so they are listed second -->
<StyleName>population</StyleName>
<StyleName>countries_label</StyleName>
<Datasource>
<Parameter name="type">shape</Parameter>
<Parameter name="file">path/to/your/unzipped/TM_WORLD_BORDERS_SIMPL-0.2/TM_WORLD_BORDERS_SIMPL-0.2</Parameter>
</Datasource>
</Layer>
</Map>
