MapServer at osgeo7
From OSGeo
Start page
Server Overview
  • hosted on osgeo7
    • dedicated container named "mapserver"
    • Debian 10 "Buster"
    • gcc (Debian 8.3.0-6) 8.3.0
Status
  • 2024-01-26
    • jmckenna: upgraded to PROJ 9.3.1, GDAL 3.8.3, MapServer-main, MapCache-main
  • 2023-10-23
    • jmckenna: upgraded to MapServer-main, changes for HTTP/2 support
  • 2023-09-15
    • jmckenna: upgraded to PROJ 9.3.0, GDAL 3.7.2, MapServer-main, MapCache-main
  • 2023-07-13
    • jmckenna: upgraded to PROJ 9.2.1, GDAL 3.7.1, MapServer-main
  • 2023-04-12
    • jmckenna: upgraded to PROJ 9.2.0, GDAL 3.6.3, MapServer-main, MapCache-main
  • 2023-04-09
  • 2022-11-28
    • jmckenna: upgraded to MapServer-main, rebooted
  • 2022-09-12
    • jmckenna: upgraded to MapServer-main, added OGCAPI: Features demo
  • 2022-09-05
  • 2022-09-02
  • 2022-08-08
    • jmckenna: upgraded to MapServer-main, restart PostgreSQL
  • 2022-06-26
  • 2022-05-17
    • jmckenna: upgraded to GDAL 3.4.3, MapServer-main, various changes for HTML Legends demo
  • 2022-03-29
    • jmckenna: upgraded to PROJ 8.2.1, GDAL 3.4.2, GeoTIFF 1.7.1, MapServer-main
  • 2021-11-20
    • jmckenna: setup Apache rewrite for old map= paths
  • 2021-11-19
    • jmckenna: upgraded to MapServer-main, various changes for tutorial
  • 2021-11-08
    • jmckenna: upgraded to GDAL 3.4.0
      • updates to all OGC services
  • 2021-11-07
  • 2021-10-30
    • jmckenna: upgraded to PROJ 8.2.0, GDAL 3.3.3, GeoTIFF 1.7.0, MapServer-main, MapCache-main
  • 2021-05-28
    • jmckenna: setup MapCache
  • 2021-05-16
    • jmckenna: upgraded to PROJ 8.0.1, GDAL 3.3.0, MapServer-main
  • 2020-10-27
    • jmckenna: upgraded to PROJ 7.2.0rc1, GDAL 3.2.0rc1, MapServer-master
  • 2020-09-11
    • jmckenna: upgraded to PROJ 7.1.1, GDAL 3.1.3, MapServer-master
  • 2020-07-24
    • jmckenna: setup server on new container, as old AdhocVM host could no longer compile recent projects (because it still runs gcc 4.7.2)
      • compiled MapServer, GDAL, PROJ from source
      • moved all demo services (except one)
Participants
  • Jeff McKenna
  • contact jmckenna for access (occurs by proxyjump through 'hop.osgeo7.osgeo.org')
MapServer Installation on mapserver container
  • home: /mapserver/
Apache Configuration
A virtualhost is setup for demo.mapserver.org, through:
  • /etc/apache2/sites_available/demo.mapserver.org
Note that a proxy is setup through osgeo7's nginx to point to the local Apache which is running on port 8081
  • server logfiles live at:
   /var/log/apache2/demo.mapserver.org-error.log
   /var/log/apache2/demo.mapserver.org-access.log
  • mapserv and other service endpoints live at: /usr/lib/cgi-bin/
Restarting Apache
  • sudo systemctl restart apache2
Adding Apache Aliases
  • add symbolic links from /var/www/demo.mapserver.org/ to your app installed in /mapserver/apps/
Services on osgeo7
For each service you configure on demo.mapserver.org, please edit /var/www/demo.mapserver.org/index.html and list your new service.
MapServer Tutorial
WMS msautotest Service
  • Simple WMS service with a latlong and mercator layer, with global extents. Used by msautotest (for GDAL testing)
  • On Disk: /mapserver/apps/msautotest/world/world.map
  • On Web: https://demo.mapserver.org/cgi-bin/msautotest?
  • Administrator: jmckenna
WMS Service (for Documentation)
  • Small mapfile serving a raster file, and a single point, line, and poly file. Used in the MapServer docs.
  • On Disk: /mapserver/apps/ogc-demos/map/wms.map
  • On Web: https://demo.mapserver.org/cgi-bin/wms?
WMS Landsat7 Service (for Documentation)
WFS Service (for Documentation)
  • Small mapfile serving a point and polygon shapefile. Used in the MapServer docs.
  • On Disk: /mapserver/apps/ogc-demos/map/wfs.map
  • On Web: https://demo.mapserver.org/cgi-bin/wfs?
WCS Service (for Documentation)
  • Minnesota DNR demo, includes MODIS and NDVI imagery. Used in the MapServer docs.
  • On Disk: /mapserver/apps/ogc-demos/map/wcs.map
  • On Web: https://demo.mapserver.org/cgi-bin/wcs?
OGR Examples (for Documentation)
HTML Legend Examples (for Documentation)
WMS OpenStreetMap Service (for Documentation)
  • OSM data for Minnesota loaded into PostgreSQL, served by MapServer. Used in the OpenLayers app on main site.
  • On Disk: /mapserver/apps/osm/osm-google.map
  • On Web: https://demo.mapserver.org/cgi-bin/umn?
Caching for mapserver.org OpenLayers viewer
  • mapcache.xml lives in:
   /mapserver/apps/mapcache/
  • mapfile:
  • seed command:
   sudo mapcache_seed -c /mapserver/apps/mapcache/mapcache.xml -t osm-mn-tileset -g GoogleMapsCompatible -z 0,13 -e -10484037,5552055,-10288486,5668255 -i scanline
  • cache directory:
   /mapserver/ms_tmp/cache/osm-mn-tileset/
MapServer 7+ CGI
main
  • A dynamically compiled "mapserv" CGI has been compiled to support V7+ demo services.
  • Web URL: https://demo.mapserver.org/cgi-bin/mapserv
  • Source build in /mapserver/src/MapServer-git-main/build
  • Administrators: jmckenna
  • build instructions for reference:
$ cd /mapserver/src/MapServer-git-main/build
$ cmake .. -DCMAKE_BUILD_TYPE=Release -DWITH_KML=1 -DWITH_CLIENT_WMS=1 -DWITH_CLIENT_WFS=1 -DWITH_CURL=1 -DWITH_FRIBIDI=1 -DWITH_GIF=1 -DWITH_HARFBUZZ=1 -DWITH_ICONV=1 -DWITH_SOS=1 -DWITH_WCS=1 -DWITH_WMS=1 -DWITH_WFS=1 -DWITH_FCGI=0 -DPOSTGRESQL_LIBRARY=/usr/local/pgsql/lib/libpq.so -DWITH_CAIRO=1 -DWITH_POSTGIS=1 -DWITH_GEOS=1 -DWITH_PIXMAN=0 -DWITH_PROTOBUFC=1 -DWITH_RSVG=1
$ make
$ cp /mapserver/src/MapServer-git-main/build/mapserv /usr/lib/cgi-bin/
