SAC Meeting 2007-01-25 agenda
(Redirected from SAC:1 25 07 agenda)
		Description of current layout and installed software
Notes from Shawn on our PEER1 system:
- OS Version: Red Hat Enterprise Linux ES release 4 (Nahant Update 4)
 - For most elements of system i tried to stay with the default redhat locations and red hat el 4 rpms installed from peer 1's up2date repository. Reasoning, the servers are updated automatically against this repository and supported by PEER1 - reduce sysadmin load on keeping packages updated by using packages not available through PEER1 repository
Installed software using up2date
- apache - httpd-2.0.52-28.ent.i386
 - postfix - postfix-2.2.10-1.RHEL4.2.i386
 - php - php-4.3.9-3.22PIDH.i386
 - python - python-2.3.4-14.3.i386
 - subversion - subversion-1.1.4-2.ent.i386
 - mailman - mailman-2.1.5.1-34.rhel4.5.i386
Red Hat EL 4 rpms installed manually (rpm -i)
- MySQL-client-standard-5.0.27-0.rhel4.i386.rpm
 - MySQL-server-standard-5.0.27-0.rhel4.i386.rpm
 - MySQL-devel-standard-5.0.27-0.rhel4.i386.rpm
 - MySQL-shared-compat-5.0.27-0.rhel4.i386.rpm
 - clearsilver-0.10.1-1.2.el4.rf.i386.rpm
 - sqlite-2.8.16-1.2.el4.rf.i386.rpm
 - python-clearsilver-0.10.1-1.2.el4.rf.i386.rpm
 - python-sqlite-1.0.1-12.el4.rf.i386.rpm
Not specific to Red Hat EL 4 rpms installed manually
- MySQL-zrm-1.1.2-1.noarch.rpm
Source Install
- drupal-4.7.4.tar.gz
 - phpldapadmin-0.9.8.3.tar.gz
 - trac-0.10.3.tar.gz
Apache
/var/www/html/
Subversion
/var/www/svn/repos/
Trac
/var/www/trac/
IP tables custom
rules must be written here or won't exist when system updated
/etc/sysconfig/iptables-custom/
System login and maintenance procedures
-- Note: if change root password must let PEER1 know the new password for backup/restore and tickets. i would prefer no root ssh login but, PEER1 needs root access.
Subversion maintanence
- subversion may lock if user ctl-c during checkout or checkout is interupted with an apache restart
 - Need policy on who to contact and who can run 'svnadmin recover' as
priviledged access is needed (may need to stop/start apache to drop requests to repository before recover)
Authorization and authentication for OSGeo services
Backups (offsite, live, and otherwise)
- PEER1 is doing daily tape backup of entire system
Other backups
- MySQL being backed up every 2 hours with MySQL-zrm
* rsync backups, to /home/back then rsynced daily to other server (osgeo.net) /etc/ (daily) /var/www/html (daily) /var/lib/mailman (every 3 hours)
/var/lib/msql-zrm (every 3 hours)
- subversion backups
-via svnadmin dump to /home/back/svn_dump/ (every 3 hours)
- trac backups
-via trac-admin hotcopy to /home/back/trac_copy/ (every 3 hours)
